Bounce Addresses
View Bounce Accounts
The bounce email accounts which have earlier been setup using the “Setup Bounce Accounts” page are listed here to view and manage. The page offers a list of all existing bounce accounts with the relevant information about each account and the ability to perform certain quick actions to manage these accounts. If you aren't login with an admin user account, you’ll only be able to view the bounce account which you have created as per the permission assigned to you by the admin.
Figure#5.2.1: View Bounce Accounts
Table#5.2.1: Viewing all Bounce Accounts
Sr
Sr is the abridged form of the serial number and in almost all the view pages of MUMARA, Sr would be the first column to start the view table with. A serial number of view bounce accounts table shows the records in ascending order (1-10).
You can view more than 10 records as well, by selecting more records to view as per your requirement. To select more records to view on the page, read the following passage under "Number of Records per Page".
Names of currently available bounce accounts.  This name is required to identify or search a particular bounce account from the list, therefore the name should be unique.
Host
The host which you have mentioned while creating the particular bounce account, this is actually the path to your bounce server or the email server to which the bounce to email belongs.
Username
The username of the bounce to the email address which you have provided while setting up the particular account.
Method
Which method or access protocol the particular bounce account is using? Whether it is IMAP or POP, the column provides the relevant information.
Port
The opening port which you have selected while creation of the bounce account. If the default ports are selected. The column will show the default opening port of IMAP (143) and POP (110) respectively.
Using PMTA
When it says “Yes” it means that the particular account has configured with advance bounce settings to process bounce from PowerMTA logs. And when it says no, it means that the account is configured with the basic settings to process the bounce without using PowerMTA.
Followed by the above mentioned details of the currently available bounce accounts, the table moves to the next column which is “Actions”. The quick action buttons allow performing the following a couple of tasks to manage the accounts.
Figure#5.2.2: Perform Quick Actions
Extension-Table#5.2.1: Viewing all Bounce Accounts (Actions)
Clicking on the edit button will directly lead you to the page where you will be able to modify the information you have setup earlier.
Click the button and you will be asked to confirm if you really want to delete the bounce account. Answering the prompt message in yes will result in the deletion of that split test permanently.
a)      Number of records per page
Figure#5.2.3: Number of Records per Page
b)      Copy or Print Bounce Accounts Table
Figure#5.2.4: Copying Bounce Accounts Table
c)      Search Bounce Account
The search box on the left side of the page “View Bounce Accounts” offers a quick way to search a particular bounce account within the application, just by typing its name or other identifiable information. Most of the time an accurate search can be conducted using the “Name” of the bounce account, as you need to provide a unique name for each bounce account you create.
As soon as you start writing in the search box, the system starts processing and sorting the bounce accounts below on the same page without refreshing. The following figure shows that even before typing the complete name in the search box; the application has searched and sorted the relevant results.
Figure#5.2.5: Searching the Bounce Account
