View Custom Fields
View Custom Fields
The table provides the relevant information of the custom fields, you earlier have created using the “Create Custom Fields“ link. Other than just information it enables you to perform various tasks like copying the table, editing the custom field details, or deleting it from the list using the action buttons. The following area describes the details of available information on the “View Custom Fields” page.
 Table#2.5.1: Viewing Custom Fields
S/N
In most of the view pages across the Mumara, S/N would be the first column to start the view table with. It shows the serial number of records on the page you are viewing.
Whenever you create an additional field, you name it according to its nature. It can be the Birthday, Gender, Occupation anything relevant to the information you collect and save using this field. The column is showing the name of the custom field.
Order
The number suggests the position of the custom field on the “Add a Subscriber” page. If it says 3, it means that the field will appear on the 3rd number followed by the fields with numbers 1 and 2.
Type
It provides information about the type of the field, whether it is a plain text field, checkbox or dropdown selection.
No of List(s)
How many lists were selected while creating the custom field.
List
The custom field only appears on the selection of the particular list during the process of adding the subscriber's details.
Perform a couple of actions using the quick action buttons under the “Actions” column at the extreme right of the table.
Extension- Table#2.5.1: Viewing Custom Fields (Actions)
Press the edit button to reach the page, where you’ll be able to edit and update the information like the type of custom field, the position of the custom field to appear on adding a subscriber page, subscriber list, and name.
Click the cross button to quickly delete the custom field from the application/ user account. A message appears on your screen to confirm the deletion. Answering the message in “Yes” will process the deletion.
Figure#2.5.1: View Custom Fields
