Mumara Classic Installation
Note: To install Mumara, you need an ionCube loader in your system. It is available on ionCube official website http://www.ioncube.com/, and the following help article provides a good amount of information on installing the ionCube loader. Follow the steps/ instructions according to your operating system.
https://www.howtoforge.com/tutorial/how-to-install-ioncube-loader/
Mumara Installation Steps
Once you are done with ionCube Installation and permissions. The first installation window that appears on the screen provides the following fields to fill with relevant information.
Login Email
Provide the email address that will be used to login Mumara as admin
Password
Provide a password to gain secure access to Mumara
Database Host
Provide the path to the database, it would be the main IP address if the database is located on the remote server, or localhost will be provided if the database resides in the installation server.
Database Username
Username assigned to access the database
Database Password
The password associated with the above-mentioned database username
Database Name
Provide the name of the database
Script URL
Provide the complete URL of your current installation, it will be your current installation domain URL with installation directory, e.g. www.yourdomain.com/memebers
Screen 2: Move to the second step by clicking “Start Installation”, the application establishes the connection to your database, after verifying the database connection; it automatically completes the installation process, by generating database schema and database tables.
Screen 3: After the installation process completes, it prompts the User Login screen to login to the application using your username and password.
Screen 4: The final step before you finally access the application is validating your license key. Simply copy your license key and paste it in the license box, and that’s it, you are successfully done with Mumara installation.
Watch the short video about the installation steps
File Permission
Following folders under the current installation requires writable permission.
/backup
/inc
/import_file
/import_file/temp
/logs
/logs/temp
/temp
/temp/campaigns
/temp/segment_export
/temp/version
/uploaded_images
/js/tinymce/plugins/image/cache
After the installation is done, you can also check the status of the file/folder permission if everything required is working OK. Navigate to check the status of File/Folder permission.
