Zapier Integration
Integrate Mumara with your Zapier account for the two-way automatic actions.
Supported TriggersSupported Actions
When a contact is added to MumaraAdd contact to Mumara
Note:
More triggers are yet to come. Zapier integration is under development and we'll be adding more triggers and actions soon.
How does it work?
Obtain Mumara API Key
Before you start, make sure that you have generated an API key for your Mumara. In order to generate one, follow the steps below.
  1. Login to your Mumara and navigate to Settings -> API key.
  2. Click on API Roles Tab and Create an API Role
  3. Give a Role Name and Description
  4. Select all privileges for the List Management and Contact Management
  5. Create an API Key and assign this newly created role to it
  6. Make sure the API Key status is set to Active
  7. Copy the API Key
 Perform an action when a contact is added to Mumara
Follow the steps below to set up a trigger using your Zapier account.
You're all set now and when there is a new contact added to Mumara, the zap will run and push the new contact to the connected application.
Add contact to Mumara when a trigger runs
The same way you have created the zap above, it's super easy to create an action that will add the contact to Mumara when the trigger runs.
More Triggers! We are in the process of developing more triggers that will help you automate more actions.
