Create web forms to embed into your website to get subscribers directly added to the contact list.
Menu Navigation: Setup - Web Forms
Here you see the list of all web forms that you have created so far.
| Field | Description |
| Name | Friendly name of the web form for identification |
| Double Optin | Subscribers are required to confirm their email addresses |
| Thankyou Email | Send a thankyou email to subscribers |
| Added On | Date when this webform was created |
| Actions |
Click on the [+Add New] button to add a new webform.
Fields:| Field | Type | Description |
| Name | Textbox | Friendly name of the webform |
| Double Optin | Switch | Enable this switch if you want to add new subscribers with unconfirmed status. Mumara will send them an instant confirmation link by email before their status will be updated to confirm. |
| Thankyou Email | Switch | Enable if you want to send a thankyou email to the new subscribers |
| Email New Contact Details To | Textbox | Insert the email address where you want to receive the notifications upon new subscribers |
| Email Content Format | Dropdown | Select which version of the email Mumara should send to the new subscribers. Or allow subscribers to decide themselves |
| Duplicates | Dropdown | Select if you want to skip the duplicate subscribers or overwrite them with the new details |
| Sending Node | Radio | Select the sending node that will be responsible to send welcome/confirmation email to the subscribers |
| Contact List | Radio/Checkboxes | Select the contact list (and the fields) that will catch the new subscribers |
| Subscription Fields | Drag & Drop | Sort the fields to match with the desired output of the webform |
Depending upon the selection in Step 1, if you have disabled the double optin option, then this step will be bypassed. If Enabled, you'll see the below output
| Redirect Subscriber To | Radio | Show Confirmation Page: Redirect subscriber to Mumara's built-in confirmation page Redirect to another Webpage: Insert the Webpage URL where you want to redirect subscriber after the webform is filled |
| Confirmation Page Content | HTML Editor | The content that you want your subscriber to see after the subscription form is filled |
| Insert Variables | Dropdown | Insert the variables from the list of options |
| Sender Name | Textbox | The name from which confirmation email will be sent |
| Sender Email | Email Address | The email address that the email will appear to be sent from |
| Reply-to Email | Email Address | Insert the email address where you want to get the replies (in case if a subscriber replies) |
| Email Subject | Textbox | The subject line of the confirmation email |
| Confirmation Email HTML Content | HTML Editor | The HTML content of the confirmation email |
| Confirmation Email Text Content | Textarea | The Text content of the confirmation email |
Set the Thankyou page and email content
| Redirect Subscriber To | Radio | Show Thankyou Page: Show Mumara's built-in Thankyou Page Take to another Webpage: Take the subscriber to another webpage after subscription |
| Thankyou Page Content | HTML Editor | The content that you want your subscriber to see after subscription completion |
| Sender Name | Textbox | The name from which the thank you email will be sent |
| Sender Email | Email Address | The email address that the thank you email will appear to be sent from |
| Email Subject | Textbox | The subject line of the thank you email |
| Email HTML Content | HTML Editor | The HTML content of the thank you email |
| Email Text Content | Textarea | The Text content of the thank you email |
In case of an error occurred, do optional settings.
| Redirect To | Radio | Show Error Page: Show Mumara's built-in Error Page Redirect to another Webpage: Insert the webpage URL where you want to redirect the subscriber upon an error |
| Error Page Content | HTML Editor | The content that will be shown to the subscriber in case of an error. (If "Show Error Page" option is selected above) |
