The page carries the list of the currently available domains for masking purposes. If you are login with the admin account, you can view the list of all available domains for masking along with the ability to perform a couple of actions to manage them. But if you are login with a user account, you’ll only be able to view the list of masking domains that you are allowed by the admin to view or you have setup using your own user account. See the following table to know more about the actions you can perform and the information which is available on the “View Domains for Masking” page.
Sr. | Following the pattern of the "View" tables within the application, the first column is the serial number of visible records in the table. |
Domain | Name of the domain which you have setup to conceal the identity of the local domain or domain of current installation. You will be able to select the masking domain while scheduling the email campaign. |
Type | The column suggests the type of mask forwarding you have applied ."htaccess” or “CNAME”. If you have a long list of masking domains, you can filter and sort the view table by masking types, typing “htaccess” or “CNAME” in the search box. This search term will sort and show the records according to the type, you have searched for. |
Listed | If that particular masking domain is blacklisted ( Listed Publically), it will show the status as "Listed" for such domains. Make sure that you have subscribed to the IP/Domain reputation monitor, in order to keep your domains checked for blacklist status. |
Last Checked | The column refers to the date when did the last time, the particular domain was checked for blacklist status. |
Followed by the above mentioned details of the currently available “Masking Domains”, the table moves to the next column which is “Actions”. The quick action buttons allow performing particular actions to manage the “Masking Domains”
Edit | Clicking the “Edit” button under “Action” will take you directly to the page, where you will be able to modify the masking domain. Make sure that if you have edited the masking domain, you will also need to update the “htaccess” or “CNAME” of the updated domain to make it work properly. |
Delete | Delete a particular domain from the list by clicking the “Delete” button next to the “Edit” under “Actions”. Before the system effect deletion, a message will appear on your screen to confirm your selection. |
The search box helps to filter or search masking domains by typing the masking domain name or the type of the type masking you have applied. The search function is too intelligent that even if you don’t remember the complete address of the masking domain, it will search the required domain by typing few initial matching words.
Furthermore, when you start typing into the search box, the application will initiate sorting the relevant domains from the lists.
