View Split Tests
View Split Tests
The page “View Split Tests” consists of the list of all existing split tests that you have earlier created using the “Create Split Test” page. If you are login with a separate user account other than the admin account, you’ll only be able to create and view a split test, if the user's role group in which your account is added, has permission from the admin to create, view, and manage split tests.
Figure#4.8.1: Viewing Split Tests
Table#4.8.1: Viewing Split Tests
Sr
Following the general pattern of all view pages in the application, the table starts with the serial number of records on page. To view all the records on one page, read the subsequent passage under records per page.
The second column under the header “Name”, contains the name of currently available “Split Tests”. The split test name is the first and mandatory field to fill, during the process of creating a new split test. The split test name will not be displayed to the recipients of the particular split test campaign, and it is used to identify the split test within the application.
Campaign
Next to the “Name”, you will be able to view the name of the campaign(s) you have selected to conduct the test and to find out the best performing campaign.
Type
From type it means the criteria you have set for the split test campaign to run, it will either be “Find Winner and Show Results” or “Fine Winner and Send to Remaining”. In the first case, the split test runs and shows the result for further planning, after evaluating the results. While in the case of selecting the second option the split test runs, evaluates the results, and sends the winning campaign to the rest of the list(s).
Created On
The column displays the date and time of the creation of the split test.
Followed by the above mentioned details of subscribers, the table moves to the next column "Actions". The quick actions buttons allow performing particular actions to manage the split tests.
Figure#4.8.2: Perform Quick Actions
Extension- Table#4.8.1: Viewing Split Tests
Clicking on the button will directly lead you to the page, where you will be able to modify the criteria set to conduct the split test.
Click the button and you will be asked to confirm if you really want to delete the split test? Answering the prompt message in yes will result in the deletion of the particular split test completely.
 a)       Number of records per page
Figure #4.8.3: Number of Records per Page
b)      Copy or Print View Split Test Table
Figure#4.8.4: Copying Subscribers Detail Table
c)        Search Subscriber
Search the details of the particular split test by using the search box towards the top right area of the page. You can search the split test by its name, or view the filtered records in the table by searching all the split tests with their type. The application will take no time to conduct this search, as soon as you start writing, the table starts sorting the records as per the search you have initiated.
Figure#4.8.5:Searching Split Test
