It offers more than just viewing the Sender IDs that the clients have applied. Admin will not only view but also will manage and activate the Sender-IDs that clients have applied. To make any Sender-ID work, it requires getting it approved from the Sending Gateway, and if the admin has configured the application with more than one Sending Gateways and have managed gateway redundancy through priority zones, it would require getting the Sender-ID approved from all gateways using which the system can send.
However, submitting a request to the gateway for the Sender-ID approval is the work that the admin would do manually through communicating with the gateways. The software doesn't play any part in submitting a request to the gateways so far. It just helps you manage, maintain, and work with the sender-ids you have got registered by the gateways.
Admin Main Navigation -> Data -> Sender IDs
Apart from the Sender-IDs using by the client accounts, the admin side also keeps a few Sender-ID to be used for Default or Fallback Sender-ID purposes. So here from this page, the admin can view all the Sender-IDs, can click to list one of the sender-IDs as its own to later offer as Default or Fallback Sender-ID. Here is how the admin registers a sender-id.
The title bar of the Sender-IDs table has the title on the left side and towards the right side, it shows a button to click and register a Sender-ID. The process is similar to getting a sender ID registered from the client account. Click the following link to learn more about the fields/selections that appear while you register a Sender-ID.
Register Sender-ID
Now let's discuss the table in which all sender-ids would appear. When a client applies a sender id and admin views it here, admin requires submitting a manual request to all gateways he has configured the system with. The following area discusses the columns of the table that opens on clicking “Sender IDs” from the admin navigation.
Serial number is the set pattern that every table across the application follows. It shows the serial number of records in the table.
Name of the client who has applied the Sender ID using his account.
Sender-ID that was being applied by the client to send the SMS from.
It shows the status of a specific sender-ID. There are different types of statuses that represent different stages of a Sender-ID. To update the Status of a sender id, you would need to visit the Edit Sender-ID page, which is discussed in detail later in this article.
Under Review- When a new Sender-ID is first applied, its status appears as Under Review. Under Review on both Admin as well as on the Client Side. It shows the client that the Sender-ID is currently under admin review and will soon be activated/registered.
Under Process- This shows that the approval of the applied Sender-ID is now in process, and will soon be updated for the next status as Registered/Rejected. It is the time when the admin actually submits the Sender-IDs to the gateways for approval and waits for their response for the Sender-ID under consideration/process.
Registered- Upon getting a response from the gateways (s), if the Sender-ID under consideration has got approved from the gateway, the admin can update the Status of such ID as "Registered". The client can only be able to use the Sender-IDs with "Registered" status.
Rejected- The admin can opt for this status if the docs that the client has submitted for the approval of Sender-ID aren't correct, or the gateway(s) has rejected a specific sender-ID.
Click Edit Sender ID under Actions in the last column in the Sender IDs table. Edit Sender ID page would help the admin perform few important administrative tasks with regard to managing the Sender-IDs. These tasks include updating the Sender-ID status and using the toggle options to switch the Sender-ID for a specific Gateway or keep it offer for others.
In the area above, we have discussed different statuses and their effects. Admin can select the appropriate one from the dropdown beside Status on the Edit Sender ID page. Make sure, the client account will only be able to send from the registered Sender-ID status, and using only those gateways that you have switched on for specific Sender-ID.
Different gateways function differently like Clickatell issues a unique API ID against every Sender ID that it approves, and it would require submitting this API ID while submitting Send Message request from the specific sender id. So if Clickatell is one of the gateways that admin is switching on against a specific sender-ID, an admin will input the ID provided by Clickatell in the field of "Clickatell API ID" before making the Sender-ID status as registered.
Filter by Client Name
This filter offers the ability to view Sender IDs specific client has applied. There is a suggestion box for making you search the required client name by typing even a few letters of the name.
