Admin of the application is being given this ability to monitor the queue of the SMS broadcasts scheduled by its clients. It gives an ability to monitor campaign processing in real-time, a proactive approach to keep a watch on campaigns getting unexpected failure rate, campaigns that were being paused, and the broadcasts active in the queue.
Admin Main Navigation -> Data -> Scheduled Broadcasts
S/N (Serial Number)
Serial number is the set pattern that every table across the application follows. It shows the serial number of records in the table.
Client Name
Name of the client who used his/her account to schedule a specific campaign.
Scheduled Label
Campaigns are always scheduled under a certain schedule label, and the label is filled as the first mandatory field during the scheduling of the campaign. So the client scheduled this campaign under that specific schedule label.
Current Status
The status will be one of the following.
In-Process while the application is in the process of sending the campaign.
Finished, when application finished sending the campaign client has scheduled.
The status will remain “Scheduled” for the campaigns that the client has set for the later date and time until the scheduled time approaches and the system starts sending to them.
Paused is the status, when you have paused a specific campaign, and Resume when you Resume the paused campaign.
Scheduled Time
A client scheduled this campaign to be sent out on this specific date and time
Activity Status
The specific campaign was last updated on this specific date and time
Total Time
If the system has finished sending the particular campaign, it will accurately calculate and reveal the time it took to complete the process of sending.
Scheduled
Total number of contacts to which the campaign was scheduled for.
Processed
The system has processed these numbers of contacts out of the total scheduled. In normal circumstances system successfully processes all the contacts for which the campaign is scheduled, with exception of few cases when an error occurs at any stage of processing.
Failed
A number of contacts to which the campaign was failed to get delivered.
Sent
A number of contacts to which the campaign has successfully been sent.
The only action you can choose to perform under the action column is "Delete" specific broadcast from the queue. If the admin deletes a broadcast, it will also get deleted from the client account it belongs to. You can't delete a campaign in progress however.
