View Scheduled Broadcasts
This page lists all of the scheduled broadcasts no matter if they are running, completed, paused, stopped or even scheduled for the future along with real-time brief statistics of numbers i.e how many were scheduled and how many have been sent.
Menu Navigation: Campaigns - View Scheduled
Below is a snapshot of previously scheduled broadcasts
Table Fields
| Field | Description |
| Name | Schedule label of the broadcast that you set while scheduling |
| Start Time | Date/Time when this broadcast was/is started/starting |
| Status | Current status of the broadcast- Starting in: Displays the timer when this broadcast is going to start
- Running: The broadcast is currently sending out emails
- Completed: The broadcast has been completed
- Paused: The broadcast has been paused manually by you
- Pausing: It appears when you pause a campaign and it has running threads in the background. This status will automatically be set to "Paused" when the already running threads are complete.
- System-Paused: The broadcast was automatically paused by Mumara due to an error
- Stopped: The broadcast has been stopped manually by you
| Contacts | Number of contacts this broadcast is going to be sent |
| Progress | How many emails have been sent so far and what percentage is left |
| Actions | - Pause: Pause a running broadcast
- Stop: Stop a paused broadcast
- Resume: Resume a paused broadcast
- Reschedule: Reschedule a completed broadcast
- Delete: Delete a paused/stopped broadcast
Search
Search across all scheduled broadcasts.
Display by Broadcast Type
Select from the broadcast types to display
- Regular Broadcasts: Displays the broadcasts that were scheduled on the contact lists
- Segmented Broadcasts: Displays the broadcasts that were scheduled on the segments
- Split Tests: Displays the broadcasts that were scheduled on split tests
Display by Broadcast Status
Select from the broadcast status to display
- All: List the broadcasts with all statuses
- Scheduled: List the broadcasts that haven't started yet
- Running: List all running broadcasts
- Completed: List all completed broadcasts
