Dynamic Content Tag offers a tool to make your email marketing more intelligent. It helps you practically implement data-driven email marketing for improving email engagements. Use of the contact details from the data fields can’t be better and more initiative than this. You draw rules for the contacts with similar details and layout a separate content that can match their preferences and behavior, and CampaignsPlus takes care of the rest. Let’s see how it works.
Menu Navigation: Campaigns - Dynamic Content Tags
Below snapshot is a view of the dynamic content tags list.
| Field Name | Description |
| Dynamic Tag | Name/placeholder of the Dynamic Content Tag |
| If Criteria Met | Content to embed if the dynamic content criteria is met |
| Else | Content to embed if the dynamic content criteria is not met |
| Added on | Date when this dynamic content tag was added |
| Actions | Edit or Delete this dynamic content tag |
Form Fields| Field Name | Description |
| Name | Name of the dynamic content tag |
| Unit Rules | Conditions of the criteria to meet |
| If Criteria Met | Content to embed if criteria is met |
| Else | Content to embed if criteria isn't met |
| Insert Variables |
When you add a dynamic content tag, it gets available in the dropdown list of dynamic tags which adding a broadcast as appear in the snapshot below. Dynamic tags are the variables inside double [[ ]] brackets e.g [[newyork-city]] as I created one above. When Mumara sees [[ ]] brackets, it considers it as a dynamic content tag and starts rendering in realtime while sending out emails.
Buttons:
Save & Add New: Save the current submission and add another dynamic content tag
Save & Exit: Save the current submission and return to the dynamic content tags page
Cancel: Cancel the current operation
