Activity Logs
An activity log is the record of the activity performed by admin, admin staff as well as the client accounts. On the client account side, the activity log table only records and populates the details of activity performed by a specific user account. However being in the administrative category, the activity logs table on the admin side records and shows activity performed by the admin, admin staff accounts as well as performed through the user accounts.
Admin Main Navigation -> Tools -> Activity Logs
S/N (Serial Number)
Serial number is the set pattern that every table across the application follows. It shows the serial number of records in the table.
Activity
The rows under this column are showing the activities that were being performed on various occasions through the application, i.e. John Scheduled a Broadcast April Campaign. In this activity statement, John is the user/profile name belonging to the account that has performed the activity, next to it is the activity that was being performed, and "April Campaign" denotes the broadcast name that John has scheduled.
Performed by
From which account the respective activity was being performed. The column is listing all the emails using which the account was created or signed in to perform the activity. Even for the admin, it shows the email that was being used to login the admin account and performing the activity that was being logged.
Performed at
The system doesn’t only record the activity that is being performed through the admin or client account, but it also logs the accurate time when specific activity was being performed. The rows under this specific column are showing the accurate date & time when specific activity was being performed.
Available Filters
Filter by Client Name
This filter offers the ability to view Activity Logs recorded for a specific client account. To apply this filter all you need to do is to select the client name from the dropdown. Suggestion box would help you quickly search and select the account of the desired client to view its activity logs.
