Contact validation is an integrated module of SMSPlus that helps client accounts to process the desired contacts for network and country lookup. The system not only gives valuable information with regard to the contacts that it processes for validation but also appropriately flags the contacts as per their validation status. It ensures that the lists will ultimately hold the most number of contacts with confirmed message delivery, and an insignificant count of the contacts that may end up on delivery failure. “Validation Settings” offers general controls and settings for the validation module.
Admin Main Navigation -> Validation -> Validation Settings
Status (Toggle Button)
Client accounts will only be able to process the contacts for validation when the admin side keeps the validation status “On”. If you turn validation status “Off” from the admin validation settings, client accounts will no longer be able to process the contacts for validation or network lookup. To offer validation/ lookup service to your clients, it is important that your current system is configured with a gateway that offers contact lookup services, and your subscribed plan includes contact validation/ lookup.
Price Settings (Per Number Lookup)
The following two fields offer the ability to setup the default value of per number lookup cost. Other than the default set lookup cost, you will have the ability to setup a separate cost for a particular package you create. If you have gone through from Package documentation, you would have an idea that SMSPlus gives you the ability to setup the type of package that seems convenient to your business model. You can setup Monthly Subscription Package, Top-Up pricing plan, or Credit Plan. Every package that you create using Setup Packages function would offer you the ability to put forward “Per Number Lookup Cost”. The system deducts per number lookup cost as set in the package on priority, but if it doesn’t find the priority settings, it applies the default per number lookup cost that you have provided in “Validation Settings”
Lookup Credit
If you have offered the client a credit-based package, how much credit will it deduct from the account of the client per contact lookup request? I.e. if you put forward 2 in this field, it will deduct two credits from the client account for every number validation request. As mentioned above, the system looks for the client’s subscribed package as a priority, and if doesn’t find per number lookup cost there, only then it applies the default cost of number validation defined in Validation Settings.
Lookup Price for Top-Up Plan
Unlike the credit plan that deducts credits from a client’s account, a top-up package cuts a certain amount of money from the balance available in the client's account. Once a client submits the request for contact validation, the system looks for Per Number Lookup Price defined in the Slab/Package subscribed by the client, and if it doesn’t find a price value there, it automatically applies the default price value set in the Validation Settings.
Prioritize Contact Lookup Service (Drag & Drop)
SMSPlus is integrated with a couple of Contact Validation/ HLR Lookup APIs offered by the sending gateways. There are drag and drop functions that would help to prioritize between the available lookup services. The system will process validation requests using the Service/Gateway up in the order, and if it somehow fails, the request automatically will be entertained through the service second in the order. For example, if you have set “Clickatell” up in the order and keeps “Infobip” as a second priority, the system will process contact validation request using Clickatell Lookup Service, but if somehow the Clickatell fails to entertain the request, the system automatically processes the request using the Service/ Gateway second in the line (Infobip).
Click “Update” to save parent settings and preferences.
