This centralized module of Notification Center gives you the ability to view and manage all sorts of important notifications under one place. For better understanding, sub-navigation divides different types of notifications. Let’s discuss each one of these sorts.
Admin Main Navigation -> Notification Center -> Admin Notifications
These are system-generated notifications and are meant to notify the super/main admin about some error, failure, resource overage of a client account, admin resource notification, and such. Some of the cases when the system will fire these notifications are.
Admin Main Navigation -> Notification Center -> Client Notifications
It intends to notify the admin about certain developments made through the client account. It prompts the admin to take an action on the client's request. Some of the cases when the system will send these notifications to the admin account are.
Apart from the system-generated notifications that we have discussed above, there are some other notifications that need to be sent as a message through email or SMS. Unlike the above mentioned types of internal system notifications, the notifications that are sent through email or SMS are editable.
Admin Main Navigation -> Notification Center -> Admin Templates
When you land on this page from the main navigation, you will see two separate boxes. One is with the title admin templates and the second with the title client templates. From here, the admin would manage the already available templates, can update the content of SMS and Email for specific notification templates, and can also add new templates for specific modules.
Before we move on and discuss the procedure of changing the content that will be sent via SMS or email. Let’s discuss “Template Mapping” at first, an option that appears right beside the titles of both the right (Client Templates) and left (Admin Templates) side sections. Clicking on it will take you to the next page. Let’s see the functionality of this page to help you understand mapping completely.
Module
Under this, you can see messages belonging to different modules, e.g. All Gateways are Inactive. It refers to a specific situation that the system can go through from. And options next to it would provide you the ability to manage this specific situation according to your preference. Here are the options.
Email
Switch it On if you want to send the notification through the email for a certain function/module. The content of the email is saved with the Notification template that you can edit using the edit option discussed later in this article. Keep this option Off, if you don’t want to send an Email Notification. In some of the cases it is almost necessary to send an email notification, i.e. Forget Password, etc.
SMS
It works the same as the aforementioned option of Email is discussed. It will send an SMS of the notification only when you have this option selected as “On”.
Roles
A dropdown option showing all the admin roles created and saved within the system. It is to control the access of admin users, as you may not want every notification being sent to every user. For the client-side section on the same page, this would show all active User Groups to control the access level. Only the Staff Roles and Client Groups selected will be sent with a notification, others will be ignored.
Template
The dropdown contains all the templates being created and saved for certain modules, i.e. “All Gateways are Inactive” can have multiple notification templates saved within the system, from here you can map a template that you find most appropriate for the specific case.
Click “Save Settings” to apply the settings
Click “Add New Template” and start adding a new notification template for a specific admin or client-side module. Each template would contain content for both Email as well as for SMS notifications.
Email Template
Select a module, provide a name to later easily recognize the template for mapping purposes, provide an email subject and create the content. You can select different types of variables for the email content i.e. %%today_date%%, to dynamically add certain values in the notification. The selection and all the fields under the Email Template are mandatory to select/fill.
SMS Template
Create content for the SMS template to use for the SMS notification. You can select different variables for the SMS content to add dynamic value in it, i.e. %%first_name%% for client template.
Click “Save Template” to save it against a certain module. You can later change a template for a specific module through the template mapping option as discussed above in this article.
The main page where you land after clicking “Notification Template” will show you a list of all available notification templates for Admin on the left side, and for the client on the right side of the page. You can select to edit any of the desired templates by clicking the “Edit” icon under Actions, this will let you update the content of the email and SMS notifications for the certain templates.
