View and manage the user accounts from the table of all available user accounts. Each user which you have created is listed in the table along with the relevant information such as the user’s role group. Click “View User Accounts” under “Create New User” in the main navigational menu to reach the page.
Sr. | A serial number of the records in the table on one page. |
Complete Name | Complete name of the user which you have provided while creating the new user account. |
Login Email | The email which you have provided while creating the new user account, for the user to login to the account. |
Group | The column shows which user’s role group the particular user belongs to. |
A couple of following actions can be performed using the action buttons.
Edit | Provides you the ability to modify and reset the details of the account selected for edition, you can change the login information for the users and can reassign a user’s role group to the selected user. |
Delete | Click the button and you will be asked to confirm if you really want to delete the user account from the database. Answering the prompt message in yes will result in the deletion of the user permanently from the database. |
Login with the User | Press the small key button to login from that particular account, the feature is exclusive for the admin user of the application to actively monitor other user accounts in the application. |
Search a user from the list of currently available users, you can type the complete name of the user in the search box to initiate the search. Or you can also view the users in a particular group, by typing the user's role group name in the search box. It will sort and will show the filtered table according to the search query, like in the following Figure#16.4.5.
