Drip Campaigns
MumaraCampaigns helps you retain the leads by keeping an auto follow-up mechanism in place. Automate customer journey from the very first interaction with your recipient to the time your lead converts into a sale. The dripping of your campaign was never that easy to configure as Mumara Campaigns has made it by refining the tedious part of automation.
Menu Navigation: Campaigns - Drip Campaigns
Table Columns
Field NameDescription
Group NameName of the drip group
Drip CountNumber of drips (follow-up) inside this group
Created OnCreation date of this drip group
ActionsView Drips: List all drips inside this drip group
Edit: Edit this drip group
Delete: Delete this drip group and all drips inside
Use the search bar to search across the drip groups.
Add Drip Group
Click on the button [+ Add Drip group] and you'll be navigated to the page as it appears below
Form Fields
Field NameTypeDescription
GroupTextName the drip group that you are going to create
Sending NodesCheckboxSelect the sending nodes that will be responsible to relay the drips. Multiple selections will put the selected sending nodes to perform in rotation
Track OpensSwitchWhether you want to track the opening of drips inside
Track ClicksSwitchWhether you want to track link clicking of drips inside
Insert Unsubscribe LinkSwitchAllow Mumara to automatically insert an unsubscribe link inside every drip email body
Sender InformationBulletSender-info of the drip email i.e sender name, sender email, reply-to email, return-path. You have multiple options here, whether to fetch the sender info automatically or insert custom info
  • From List: Fetch sender-info from Contact List details
  • From Sending Node: Fetch sender-info from Sending Node details
  • Custom: Use/select custom sender-info for this drip group
    Note!
    From Name: Whether to insert a custom Sender-Name or fetch from the selected option
Sending DomainBulletAs Specified in Sending Node: Fetch the sending domain as per the selection in Sending Node
Select from Sending Domains: Select from the dropdown list of your sending domains
Buttons
Save & Add New: Save this drip group and stay on the same page to add new
Save & Exit: Save this drip group and navigate to the drips page
Cancel: Cancel the operation and go back to the drip campaigns page
Drip Groups!
Drip groups are helpful to keep the individual drips categorized and carries information of sending nodes being used to relay the drips along with some more important information i.e sender-info, engagement tracking, etc
Add a Drip
  1. There are two ways to Add a Drip. Click on the [+ Add a Drip] button as appears in the screenshot below
  2. Click on Drip Count and then click on the [+ Add a Drip] button (on view drips page)
Step 1: Setup
Adding a drip is a 3-step wizard that carries information of the drip e.g email content, sending interval, drip group etc.
 Step 2: Interval
Define when to execute this drip after the trigger. As when you are adding a series of drips, you'll surely need to set a time delay between two consecutive drips. In Mumara, the reference point is the date/time when the trigger was executed so every drip will refer to the time delay from the trigger initiated date/time.
When to Send:
Step 3: Message Body
Form Fields
FieldDescription
Email SubjectSubject line of the drip email that your recipients will receive
HTML BodyHTML version of the email body
Text BodyText version of the email body
Insert Variables
  • System Variables
    • Sender Name: It inserts the name of the sender who is sending the email (depends upon the selection of sender-info while scheduling the broadcast)
    • Sender Email: Inserts the email address of the sender
    • Recipient Email: Inserts the email address of the recipient receiving the email
    • Reply-to Email: Inserts the email address mentioned in Reply-To of the sender-info
    • Bounce Email: Also known as Return Path. It inserts the email address that is set to receive bounces in sender-info
    • Today's Date: Inserts today's date
    • Web Version: It inserts a unique URL that takes the recipient to the web version of the email
    • List Name: Inserts the name of the list to which recipient belongs
    • List ID: Inserts the ID of the list to which recipient belongs
    • Message ID: Inserts the realtime generated message-id of the email going out
    • Campaign ID: Inserts ID of the broadcast
    • Sending Domain: Inserts the sending domain as appearing in sender-info of the selected criteria
    • Confirmation Link: Inserts a unique URL that updates the contact's status as confirmed (upon click)
    • Unsubscribe Link: Inserts a unique link that sets the recipient subscription status as Unsubscribed
  • Additional Fields
    • Contact ID: Inserts ID of the contact
    • Other Additional/Custom Field: Inserts the value of additional/custom field (if any)
  • Spintags: Inserts one random value from the list of values for the selected spintag
  • Copy as Text: Auto-creates a TEXT version of the HTML content and inserts into textarea
Preview Sending NodeSelect a sending to send a preview of this drip
Preview EmailWrite the email address where you want to receive the preview of the drip
List all Drips
  1. You can list all drips by clicking on the Drip Count on drip groups page      OR
  2. Click on the Actions button for the drip group and click "View drips"
Fields
FieldDescription
DelayTime interval of the drip i.e when to be sent after the trigger
StatusActive or Inactive. Inactive drips will not be executed
Created onCreation date/time of the drip
ActionsEdit: Edit this drip
Write a keyword in the search bar to search across all drips
Sort by Drip Group
Select drip group(s) from the dropdown below the [Drip Groups] button as shown in the picture above to list the associated drips in the table.
How to start a drip group?
If you are wondering to start drips then a quick answer to this is, you have to create a trigger on the defined event and select "start a drip group" from the list of actions.
