Sr. | Serial number of records in the table. |
Schedule Label | A campaign schedule label is something that helps to identify the scheduled campaign, across the scheduled ADK campaigns in the queue. This column also appears on the page “View Scheduled Campaigns”. |
Campaign Name | You may find this column empty for ADK stats because you don’t use the application to create ADK campaigns, it's Adknowlege which sets up a campaign under your Adknowlege campaign ID. |
List Name | Name of the subscriber list(s) you have scheduled the particular campaign for. |
Schedule Time | Don’t get confused, it isn't the time when the campaign was first created or scheduled. It is the time on which the campaign was scheduled to start the sending process. |
Scheduled Status | The column shows the total number of subscribers for which the campaign is scheduled for. You will be able to see the message “Total Subscribers in List(s) on mouse hover. |
Sent | Shows the number of subscribers to which the ADK campaign is being successfully sent. So the schedule status column shows the total number of subscribers to which the campaign is scheduled, and this column shows the number of subscribers this campaign is being sent to. |
Bounced/Unsubscribed | A number of bounced back emails and number of subscribers who opted to unsubscribe the mailing list, as a result of receiving the email message. |
Opened | The column displays the results of both, total opens and unique opens. The person who opens the campaign is known as an opener, and the action is marked as open within the application. Unique opens point out the action of the subscriber who first time opens the ADK campaign and does not repeat the action. If the subscriber reopens the email by repeating the action, this repeated action will not be considered as unique open. |
Clicked | The same goes for unique and total clicks as described above for the unique opens and total opens. |
The action column provides the ability to go advance and view the detailed summary of statistics, perform particular actions such as filtration of the records and exporting the records to a file. After you click “View Detailed Stats” under the “Actions” column, you will be taken to the next page to view the detailed stats and perform related tasks with ease.Figure#14.2.2 shows how the detailed page looks like and what information it gives.
The search box helps to search a particular campaign from the list of sent ADK campaigns. If you have sent a good number of ADK campaigns, this helps you to search and view results of a particular ADK campaign from the long list. Cut the process short, just type some unique identifiable information into the search box like schedule label to search the particular ADK campaign.
a) Campaign Summary
The first tab offers you a detailed summary of the campaign, which includes information such as campaign type, name of the selected campaign(s), selected subscriber list(s) to send this campaign to, the status of the campaign, and a brief of other related information.
b) Opens
Next to the campaign summary, a table opens along with the details of the subscribers who opened the ADK campaign. The table contains the following information about each opener.
Email address of the subscriber who opens the ADK campaign. | |
Opened Time | The exact time when the subscriber opens the email, he/she received. |
Opener’s IP | The IP using which the email has been opened by the subscriber. |
City | City in which the email is being opened by the recipient/subscriber. |
Region | Regional information where the subscriber was located when opening the email. |
Country | Country to which the IP address of the opener belongs to. |
Use the copying options to copy the data in the columns of the table that appears below. You can copy the table by using the “Copy” button and can paste it manually in a file or can copy and save the complete table along with the columns to .CSV file, Excel, or PDF format. Further, you can get a print out of the complete table by clicking “Print”. See the following figure
Filter the records based on the opener’s country, select a country from the dropdown to view the details of the opens from the selected country. You can further copy the filtered records using the copying options as discussed above. . You can copy the table of filtered records by using the “Copy” button and can paste it manually in a file, or can copy and save the filtered table along with the columns to .CSV file, Excel or PDF format.
Email address of the subscriber who clicks the link in the email he/she receives. | |
Clicked Time | The exact time when the subscriber clicked the link. |
Clicker’s IP | The IP using which the link has been clicked by the subscriber. |
Link | The link that was being clicked. |
City | City in which the link is being clicked by the subscriber/ recipient. |
Region | Regional information where the subscriber was located when clicking the link. |
Country | A country to which the IP address of the clicker belongs to. |
Use the copying options to copy the data in the columns of the table that appears below. You can copy the table by using the “Copy” button and can paste it manually in a file or can copy and save the complete table along with the columns to .CSV file, Excel, or PDF format. Further, you can get a printout of the complete table by clicking “Print”. See the following figure
See Figure#14.2.5 Above
Filter the records based on the clicker’s country, select a country from the dropdown to view the details of the clicks from the selected country. You can further copy the filtered records using the copying options as discussed above. You can copy the table of filtered records by using the “Copy” button and can paste it manually in a file or can copy and save the filtered table along with the columns to .CSV file, Excel, or PDF format.
b) Bounced
Next to the clicks, the bounced tab opens up the table, which provides even the minor details of the bounced back emails. The table provides the following information.
Sr. | Sr is the abridged form of the serial number and in almost all the view pages of MUMARA, Sr would be the first column to start the view table with. |
The email which bounced back as a result of sending the ADK campaign. | |
Bounced Time | The exact time when the system received this email as a bounce. |
Bounce type | The type of the bounce between hard and soft. Hard bounce shows the permanent delivery error, while the soft bounce is a momentary delivery issue. |
Bounce Code | Whenever an email is bounced, it bounces back with a reason, why these delivery problems occur. Each bounce reason has its own error code, and most of the general delivery issues and their codes are categorized as per the industry standards. The column shows the error/bounce code associated with the bounce reason. |
Bounce Reason | As described in the above field for “Bounce Code”, there are reasons behind each email that bounced back. The column shows that reason. |
Integration of the bounce account with the VMTA based application PowerMTA helps to go forward to find out the advance details of the delivery issues. You will be able to view the advance details in the columns after “Bounce Reason”, only if the bounce account has been integrated with PowerMTA for processing and collection of the bounce stats. The following table describes what advance stats of the bounced email, the PMTA bounce processing can collect.
Bounce Details | Along with the bounce reason and the error code, the bounce processed using the PMTA presents a delivery issue in detail. The column carries the appropriate detailed message, why the delivery issue occurred, and why the email sending of the email is being rejected? Is it due to the spam content, recipient address rejected it, rejected because the network is on blocklist or some temporary problem occurred? This detailed information further helps to troubleshoot and fix the delivery issues and improve the results. |
DNS MTA | It refers to the MX host/ mail exchange host of the recipient, responsible of processing the transmission details received from the sender MTA within the server application infrastructure. |
DLV Source |
DNS Destination |
VMTA | Virtual MTA or simply VMTA is the technology that PowerMTA uses to extend your control on your email stream and enables you to manage the IP address separately for even a single message which is being sent. This column shows information about the VMTA of the bounced back email. |
VMTA Pool | The column refers to the pool of the VMTA using which the email is being sent, and eventually bounced back. As described above, to ensure standardized bounce categorization, details of non-delivery reports along with the classified information of sending infrastructure is key. |
Filter by Error Code
Error codes and Bounced reasons have already been elaborated while discussing “Setup Bounce Reasons”. The first dropdown offers the ability to filter the records with their bounce codes, an example of this is selecting 5.0.0 will filter out the email addresses which does not exist.
Filter by Bounced Reason
The second option is to filter the records with the bounce reasons. There are set industry standards for bounce reasons and their error codes. However, MUMARA allows setting up manual bounce reasons as well; reach “Setup Bounce Reasons” for more details. Select one of the bounce reasons from the dropdown to filter the records accordingly. For example, a bad destination mailbox address (5.1.1) will show only the filtered records.
Filter by Type (Hard or Soft)
Keep the dropdown option at “All Bounces” if you don’t want to filter records based on bounce type. Select “Soft” to separate out the soft bounces only, and select “Hard” to filter and show the hard bounces of the ADK campaign.
Mark Filtered
Mark the filtered bounce records as soft by clicking the button “Mark as Soft”, and mark the filtered records as hard by clicking the button “Mark as Soft”. Permanent delivery error is called “Hard Bounce” and the momentary delivery issue is considered as the “Soft Bounce”. The application stops sending further campaigns to the emails marked as hard bounce within the system. But at times you may need to mark some hard bounce as “Soft” for further emailing; it is where these two buttons help.
Copy the Filtered Records
You can further copy the filtered records using the copying options as discussed earlier. You can copy the table of filtered records by using the “Copy” button and can paste it manually in a file or can copy and save the filtered table along with the columns to .CSV file, Excel, or PDF format.
Refer to Figure#14.2.5 Above
The numbers of subscribed contacts from the selected list(s) who request to stop receiving further emails are known as unsubscribed. When you send emails in bulk, it is likely to have a less personal relationship with each contact you have sent the ADK campaign to, therefore knowing the unsubscribed contacts is important, and removing them from the list to stop further emailing to them is recommended. The table that follows provides required information about the contacts who unsubscribed.
Sr. | Sr is the abridged form of the serial number and in almost all the view pages of MUMARA, Sr would be the first column to start the view table with. A serial number of view all campaigns table shows the records in ascending order (1-10). |
Email of the person who unsubscribed from the mailing list recommended sending practice is to keep your list updated against the unsubscribed request. | |
Unsubscribe Time | The time when the system received the unsubscribe request from the subscriber. |
Copy Unsubscribed
Figure#14.2.5 Above
The table which follows contains the information of the subscriber who marked the received email as spam. The reasons for spam can be several, but to fix these reasons and improve deliverability, the key is obtaining and keeping the record of the spam/abuse complaints about further actions.
Sr. | A serial number of records in the table. |
Email of the person who marked/hit the email as spam, as the spam directly affects the reputation of sending IP, and email stream. Therefore it is recommended to process the spam/abuse complaints as soon as you receive them, always implement Feedback loops. | |
Complain Time | This refers to the time when the system received the complaint. |
Figure#14.2.5 Above
Besides the general ADL campaign information, the logs table contains some of the stats as follows.
This refers to the “From” email, the email using which the campaign is being sent. | |
Campaign Name | You may find this column empty for ADK stats because you don’t use the application to create ADK campaigns, it's Adknowlege which sets up the campaign under your Adknowlege campaign ID. |
SMTP Label | MUMARA allows setting up as many SMTP accounts as you want. The column refers to the name of the SMTP account which is being used to send this ADK campaign. |
Sending Time | The time it took to complete the sending of the ADK campaign to the subscribers of the selected list(s) |
Bounced | The number of emails bounced back as a result of the ADK campaign. |
Unsubscribed | Numbers of contacts/subscribers who requested to stop sending further emails by opting to unsubscribe from the mailing list. |
Status | Current status of the campaign, is it in process of sending, completed the course of sending, or paused? |
DNS MTA | It refers to the MX host/ mail exchange host of the recipient, responsible for processing the transmission details received from the sender MTA within the server application infrastructure. |
DLV Source |
DNS Destination |
VMTA Pool | The column refers to the pool of the VMTA using which the ADK campaign is being sent. |
Details |
