The page consists of the list of currently available PowerMTA servers, if no PowerMTA servers were added, the rows and columns of the view table will remain empty. Reach "PowerMTA Servers" in the main navigation menu, under "Integrations" to view the list of the PowerMTA servers.
The table in the figure above will provide the following information about the currently available PowerMTA servers.
Server Name | Name of the server that you have provided during the process of adding a new PowerMTA server, as the first mandatory field. |
| SMTP Host | The SMTP Host being proposed for that particular PowerMTA server, it was provided during the first step of adding a new PowerMTA server. |
| SMTP Port | It refers to the opening port for the SMTP that you have proposed while adding this PowerMTA server. Port25 is largely known as the default SMTP port, but some ISPs have this default behavior to block port25. It can be a port 25 or an alternative opening ports like 2525, 2526 (SSL), and 587. |
| Server IP | PowerMTA server IP for SSH access. |
| PowerMTA Port | This refers to the port of the PowerMTA logs file, and it was required to configure remote bounce processing directly from PowerMTA logs. |
Followed by the above mentioned details of the currently available PowerMTA servers, the table moves to the next column which is “Actions”. The quick action buttons allow performing the following actions.
Extension: Table#13.4.1: Perform Quick Actions
Edit | Clicking the Edit button will take you to the page, where you will be offered the required fields to update the earlier saved information. |
| Delete | Clicking the cross button will delete the PowerMTA server from the list. |
| Delete Config | The trash button at the extreme right side of the table will not only delete the PowerMTA server entry but will also remove the config associated with that particular PowerMTA server. It includes deletion of the SMTP accounts, bounce accounts, and masking domains from MUMARA. |
