Like the other “View” pages of the MUMARA, the “View Spin Tags” page offers a list of currently available spin tags with an ability to further manage and modify them. In case of logging with a user account, you’ll only be able to setup and view spin tags, if the admin account allowed the permission to create and view spin tags to the User's Role Group you are in. Submenu of “Spin Tags” contains this “View Spin Tags” page under “Setup Spin Tags”. See Table#8.2.1 followed by Figure#8.2.1 for details of information it provides.
Sr. | Serial number of the records displaying in the table to view, you can view more than ten records as well, and also all the records per page. Read "Number of Records per Page" in the following area, to view more than 10 records in the table. |
Placeholder | The placeholder text is used to identify the particular spin tag among the list of spin tags. The column displays the text you have provided earlier in the placeholder field while setting up the spin tag. |
Couple of following actions can by performed by clicking the action button, under the extreme right column of the view spin tags table.
Edit | Clicking “Edit” button will take you to the “Edit” page, where you will be able to reset the “Placeholder” field with the list of the words to replace the placeholder. |
Delete | Click the cross button to delete particular spin tag from the list. Deletion will effect once you confirm the prompt message, which appears after clicking the cross button. The message will ask to confirm the removal of the spin tag from the list. |
To select the number of records you want to view per page, the page puts a dropdown menu on view towards the top of the page. The dropdown menu starts from 10 records to display, and ends with all records on one page. The following figure indicates the position of the dropdown on the page.
Use the copying options to copy the data in the columns of the table appears below. You can copy the table by using the “Copy” button and can paste it manually in a file, or can copy and save the complete table along with the columns to .CSV file, Excel or PDF format. Further you can get a print out of the complete table by clicking “Print”. See the following figure.
The searching criteria for the spin tags from the list of all available spin tags is the text in “Placeholder”. You can start by typing few words of the placeholder in the search box, and you’ll see the application start sorting the results, according to the search query.
