The following guide will help you install Mumara Campaigns self-hosted version.
Make sure that you have the minimal edition of the operating system. Login to your OS as a root user and run the command below. It will install all dependencies including Apache, MySQL, PHP to install Mumara automatically.
cd /home && curl -o installer -L https://dl.mumara.com/campaigns/installer && sh installerWe suggest running this command on the Linux screen to avoid losing operation upon connection break. If your server doesn't have a screen installed, then you can install it using the command yum install screen.
Supported Operating Systems:
- AlmaLinux 9 (minimal)
- AlmaLinux 8 (minimal)
- CentOS 8 (minimal)
SELinux Check:
It will check to disable SELINUX if found enabled and reboot the server. After reboot, you'll need to run the command again.
During the process, it will ask you certain questions to understand the basic things and install the correct license to the correct domain. Make sure that your license status is re-issued before starting the installation.
Finalizing the purchase order will lead you to your billing account. If you are unsure about your billing panel then navigate to https://billing.mumara.com/clientarea.php and log in using your credentials.
Navigate to Services -> My Services.
Click on the product name and find the “Download Now” button.
Unzip the downloaded files and upload them to your website root folder. Mumara Campaigns isn’t suggested to be installed in a sub-directory e.g yourdomain.com/mumara etc due to dependencies issues. So host it on your main domain or you can even use a sub-domain to be installed on. Once the files have been uploaded, make sure that it has a .htaccess file inside as most of the FTP applications consider .htaccess as a hidden file(s) and skip such files during transfer.
Mumara Campaigns comes up with a built-in installer that checks dependencies and files/folders permissions before proceeding with the installation. So you need to make sure that you have a MySQL database already created and a user has already been assigned to it.
Now open your domain name on which you have uploaded Mumara files. It will auto-detect if Mumara hasn’t previously installed and will redirect you to the installer. If it doesn’t happen, you can always access the installer directly by putting /install at the end of the URL e.g mumara.yourdomain.com/install.
Ioncube Installation
One of the requirements to get the Mumara Campaigns installed on your server is the ionCube loader. Your Apache must be compiled with the correct version of the ionCube loader to match your server’s PHP version. You can download the ionCube loader from their official website here http://www.ioncube.com.
A short help guide like the following provides a good amount of information on ionCube installation.
https://www.howtoforge.com/tutorial/how-to-install-ioncube-loader
If you have any control panel installed on your server (e.g cPanel, Plesk, etc), it covers almost all dependencies by default. If your server/VPS is having minimal OS installation, you will need to look at the following required tools before proceeding with the installation.
Webserver e.g Apache, Nginx
MySQL 8.0
InnoDB Table Support
PHP 8.1
Cron Support
Ioncube12
OpenSSL
PDO
Mbstring
Tokenizer
XML
Ctype
JSON
BCMath
IMAP
SSH2
Curl
Iconv
Domdocument
Zip
Fileinfo
allow_url_fopen
url_include
exec
shell_exec
memory_limit (minimum 512M)
You need to give writable (777) permissions recursively (all content inside including sub-folders and files) to the folders mentioned below.
\bootstrap\cache
\storage
.env (create this file if doesn't exist)
Do whitelist the following IPs on the mentioned ports permanently if you have a firewall running on your server. It will allow your Mumara to update with a single click when we have updates available.
Type
IP
Ports
Update Server
103.181.98.8
80, 3306
Licensing Server
103.181.98.69
80
