Custom Fields
Custom fields are used to store additional data of your leads/contacts other than just email addresses e.g first/last name, company, country, phone, etc.
Menu Navigation: Lists - Custom Fields
Predefined Custom Fields (Additional Fields)
To make things simpler, you’ll find predefined optional custom fields that are being used more often. The predefined custom fields are categorized as additional fields and contain the following.
Field NameTypeDescriptionTitleTextboxTitle of the contact e.g Doctor, Engr, Mr. Mrs., etcFirst NameTextboxFirst name of the contactLast NameTextboxLast name of the contactBirth DateDateIt’s a date field and insertion just accepts date valuePhoneTextboxIt’s a text field as sometimes the number format contains spaces and hyphensMobileTextboxMobile number of the contactCompanyTextboxCompany name of the contactCountryDropdownSelect the country of the contact from the dropdownStateTextboxCountry’s state of the contactCityTextboxCity of the contactZip CodeTextboxZipcode if the contactFaxTextboxFax number of the contact
OperationDescriptionEditTakes you to the edit page where you can modify the pre-filled valuesDeleteIt deletes the custom field
Adding a custom field
On the custom fields page, click on the button [+Add New] that will take you to the custom field form where you can define a new field and assign it to multiple desired contact lists right away.
Snapshots of Field Types:
Text Field
Date Field
Checkboxes
Dropdown
Radio Options
Buttons
Save & Add New: Save the current record and stay on the same page to add another.
Save & Exit: Save the current record and navigate to the custom fields page.
Cancel: Cancel the operation and go back to the custom fields page.
